January 14, 2016, 12:19 |
Observing part deformation fluent
Harsimrat Singh Sandhu
Hi
I am working on a project in which I need to observe the deformation (and eventual rupture) of a cylinderical column in elongational flow. I have already modelled the geometry for the flow (in 2D). Now I want to know how to put my column in fluent (the one which will deform due to the fluid flow) and observe what shape it will take at different time steps. I am working on lamilar flow with low Reynolds numbers, without considering the energy equation, so I am not using any complex solution system. The material, at this moment, does not matter. Thank you :-) |
[snappyHexMesh] crash sHM | H25E | OpenFOAM Meshing & Mesh Conversion | 11 | November 10, 2014 11:27 |
Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 10:54 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 02:00 |
Fluent jobs through pbs | ibnkureshi | FLUENT | 5 | June 9, 2011 13:43 |
Fluent 12.0 is worst then Fluent 6.2 | herntan | FLUENT | 5 | December 14, 2009 02:57 |
