Very strange problem with DPM combustion model |
January 21, 2016, 06:47 |
Rep Power: 11 |
Hi guys.
I encountered very strange problem with ansys fluent I try to simulate non-premixed combustion process in ansys fluent. I have injector which inject particles into pipe and after some time particles starts to evaporate. Evaporated particles ignites and produces heat, pressure and etc. But I encountered strange particles behavior. Particles starts to appear in various places (please see video) https://www.youtube.com/watch?v=pCqLEM73JOA P.S. mesh is adapted by these gradients every time step. Maybe someone have encountered same problem ? It would nice to know someone has solved this problem because I am out of ideas... Code:
mark_pres adapt/mark-with-gradients pressure space-gradient 2 yes 0.1 0.01 no 0 0 0 mark_vel adapt/mark-with-gradients velocity space-gradient 2 yes 0.1 0.01 no 0 0 0 mark_turb adapt/mark-with-gradients turb-kinetic-energy space-gradient 2 yes 0.1 0.01 no 0 0 0 dpmcolrat adapt/mark-with-gradients dpm-collision-rate space-gradient 1 yes 0.1 0.01 no 0 0 0 dpmcons adapt/mark-with-gradients dpm-concentration space-gradient 1 yes 0.1 0.01 no 0 0 0 dpmsen adapt/mark-with-gradients dpm-omega-source space-gradient 1 yes 0.1 0.01 no 0 0 0 dpm2 adapt/mark-with-gradients dpm-sensible-enthalpy-source space-gradient 1 yes 0.1 0.01 no 0 0 0 dpm3 adapt/mark-with-gradients dpm-tke-source space-gradient 1 yes 0.1 0.01 no 0 0 0 dpm4 adapt/mark-with-gradients dpm-total-enthalpy-source space-gradient 1 yes 0.1 0.01 no 0 0 0 combine adapt/combine-registers 0 1 2 3 4 5 6 7 8 display adapt/display-register 9 adapt adapt/adapt-to-register 9 0 0 yes Code:
Injecting 2 particle parcels with mass 3.36e-07 at t = 0.000661 Advancing DPM injections .... iter continuity x-velocity y-velocity energy k omega fmean fvar time/iter ! 637 solution is converged number tracked = 2159, escaped = 0, aborted = 0, trapped = 0, evaporated = 17, incomplete = 0, incomplete_parallel = 0, collided = 628, shed = 25 637 9.3974e-04 8.4527e-09 5.1602e-09 6.6863e-08 1.9989e-08 3.7411e-06 0.0000e+00 0.0000e+00 0:00:06 30 638 1.1210e+00 1.1691e-01 1.2427e-02 8.0195e+03 9.9664e+01 9.0283e+00 0.0000e+00 0.0000e+00 0:00:05 29 absolute pressure limited to 5.000000e+10 in 4 cells on zone 8 Maximum PDF table enthalpy exceeded in 2 cells on zone 8 . Minimum PDF table enthalpy exceeded in 3295 cells on zone 8 . turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 12269 cells # Divergence detected in AMG solver: pressure coupled -> Decreasing coarsening group size! # Divergence detected in AMG solver: pressure coupled -> Increasing relaxation sweeps! # You may try the enhanced divergence recovery with (rpsetvar 'amg/protective-enhanced? #t) Divergence detected - temporarily relaxing and trying again... Divergence detected - temporarily relaxing and trying again... Divergence detected - temporarily relaxing and trying again... Divergence detected - temporarily relaxing and trying again... Divergence detected - temporarily relaxing and trying again... Maximum PDF table enthalpy exceeded in 6 cells on zone 8 . Divergence detected in AMG solver: pressure coupled Divergence detected in AMG solver: pressure coupled Divergence detected in AMG solver: pressure coupled Divergence detected in AMG solver: pressure coupled Divergence detected in AMG solver: pressure coupled Divergence detected in AMG solver: pressure coupled Divergence detected in AMG solver: pressure coupled Error at host: floating point exception Minimum PDF table enthalpy exceeded in 3285 cells on zone 8 . Error at Node 0: floating point exception Error at Node 1: floating point exception Error at Node 2: floating point exception Error at Node 3: floating point exception Error at Node 4: floating point exception Error at Node 5: floating point exception Error at Node 6: floating point exception turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 12283 cells Error: floating point exception Error Object: #f Last edited by gamemakerh; January 21, 2016 at 07:10. Reason: update |
Combustion Model - Laminar Flamelet Model | spg1g14 | CFX | 0 | August 5, 2015 18:13 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
combustion problem | mcnair | CFX | 9 | March 22, 2011 14:06 |
Problem importing watertight model into CFX | djk1301 | ANSYS | 3 | February 1, 2011 22:04 |
DPM model w/ Wave model - errors in documentation | HS | FLUENT | 0 | April 12, 2006 04:37 |
