Pressure Boundary Condition
Like Tree2Likes
  • 1 Post By LuckyTran
Prev Previous Post   Next Post Next
Old   January 22, 2016, 08:17
Default Pressure Boundary Condition
Dave M.
Dave_88 is on a distinguished road
Hello everyone,
I need to clarify a general boundary condition issue.
I have got a pressure inlet for a compressible flow with air. I have received the values for the boundary conditions from experimental data, which allows me to specify static pressure, total pressure and turbulence parameters. In my theoretical calculation my inlet should have:
u=60m/s
p_st=97,878Pa
T=289K
=>rho=1.1785kg/m³ (resulting from isentropic change of state with pi=0.97878)
p_tot= 100,000Pa
Using a pressure inlet allows me to specify the total pressure and an initial guess for static pressure. After a converged calculation, the solution values for the inlet show different values. The mean velocity is about 88m/s and the static pressure 95,400Pa, which is completely wrong.
Does anybody know, how a) to correctly input the boundary values, that the results show the values I want to see and b) why there are those differences? (velocity inlet does not work here)
Help is much appreciated.
Regards
Dave_88 is offline   Reply With Quote
Appropriate pressure boundary condition in incompressible flow lonelywing OpenFOAM Running, Solving & CFD 21 June 6, 2022 09:44
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
pressure outlet boundary condition hamid_reza Fluent Multiphase 1 September 9, 2014 13:43
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
