Aizaz
Rep Power: 10 ![]() |
Hi everybody,
I am currently working on my final year project and designing and simulating compression ignition engine. I have done the geometry work of piston bowl. The problem i am facing is that when I am done with the pre-mesh and write the output to be exported into the Fluent Solver, then after I check the mesh in Fluent, i get the Mesh Check Failed error. I am attaching the ICEM CFD file upto pre-mesh. Kindly look into it and tell me if there is anything wrong while exporting it to Fluent so that I don't get any non-positive volumes or mesh check errors. It will be of great help Thankyou |
Aizaz
I am new to this forum so I apologize for any mistake I may have made regarding rules
Aizaz
This is current state of mesh.
Acticate "Penetrating Elements" in the Check Mesh Panel in ICEM. It is disabled by default. Penetrating elements can cause non-positive-volumes.
Aizaz
How do i check zero or negative qualty?
Rep Power: 18 ![]() |
ansys 15, fluent 15, icem 15 |
Loosing Volume, High Simulation Time and Problem About stl File | thetitans | FLOW-3D | 3 | December 1, 2016 06:36 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
multiphaseEulerFoam (OF2.3.0) : Courant number explodes when running in parallel | Mehrez | OpenFOAM Running, Solving & CFD | 10 | May 18, 2016 11:44 |
multiphase turbulance case floating error | harsha_kulkarni | OpenFOAM Running, Solving & CFD | 3 | February 18, 2016 05:06 |
Negative-cell volume error for water entry problem | stefanos | FLUENT | 0 | January 19, 2013 09:23 |
