Horizontal fluid flow
Old   April 4, 2016, 05:35
Default Horizontal fluid flow
pranay
pranaychowdary is on a distinguished road
Hello everyone,
I'm trying to do a project in which a fluid flows horizontally by centrifugal force,In this problem a oil tank(sump) is placed at the bottom and a rotating component which sucks the oil from the oil tank and supplies it to top of the component to a reservoir,so what I need to do is :How to create a two phase fluid in the oil tank,I need stepwise to fill the tank with two liquids of my choice, can anyone help me with this..
pranaychowdary is offline   Reply With Quote
Old   April 4, 2016, 06:38
Surya
hariswch2 is on a distinguished road
Hello pranaychowdary, you can use multiphase model to capture two phases..i recommend volume of fluid method for your problem..good luck
hariswch2 is offline   Reply With Quote
Old   April 4, 2016, 06:49
pranay
Hi hariswch2 ,Actually the part I do not know is how to create fluid volume in the bottom oil tank.
Old   April 4, 2016, 07:41
Surya
You can use PATCH option in solution initialization to define the volume fraction (0 or 1) for your fluid volume with dinemsions
Old   April 4, 2016, 08:16
pranay
Do I have to give any options in design module or while meshing,what should be the oil bottom defined in name selection.Is it given as inlet.
Old   April 5, 2016, 01:09
Surya
No need to give any options in design module...just you have to give dimensions of oil filled volume in PATCH option....it means that fluent will take initially oil is filled in that particular volume
Old   April 5, 2016, 01:13
Surya
Can you show me the layout of your problem for better understanding
Old   May 2, 2016, 13:18
pranay
You said dimensions can be given in patch option I would like to know how.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Multiphase flow with two continuous fluids and one dispersed fluid ashtonJ CFX 5 July 25, 2014 06:31
Two-phase flow in a circular horizontal pipe DmitryS Fluent Multiphase 0 May 17, 2014 16:22
Newbie: advantages/disadvantages of "penalty formulation" incompressible fluid flow bzz77 Main CFD Forum 2 November 1, 2011 03:32
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
