flow over cavity
Like Tree1Likes
  • 1 Post By mostanad
Old   May 22, 2016, 13:52
Default flow over cavity
mohammad
mostanad is on a distinguished road
hello everybody
i am investigating about boundary layer flow over cavity. i am using fluent for simulating this geometry. my solution doesn't converge. i know it's because boundar conditios. is any bodey say me boundary conditiod specially in outlet.
saeedhayati likes this.
mostanad is offline   Reply With Quote
Old   May 22, 2016, 14:50
Moh'd Khasawneh
MAK_JUST_University is on a distinguished road
Dear Mohammad
Inlets should be specified through static pressure, mass flow rate or velocity
Walls should be specified as wall boundary condition (no slip)
outlet might be specified outflow or zero relative pressure
in addition you might define an enclosure to define the fluid domain
Yours
Moh'd
MAK_JUST_University is offline   Reply With Quote
Old   May 22, 2016, 15:07
mohammad
Originally Posted by MAK_JUST_University View Post
Dear Mohammad
Yours
Moh'd
thank you for replying to me.
if i write an fortran code for this domain, which b.c can be use for outlet??? the procedure of solving is solving of vorticity-stream function equatios. can i use fully developed flow for outlet??? how i should draw after cavity for this condition???
Old   May 22, 2016, 15:27
Moh'd Khasawneh
you are welcome
if i were you i would assume the pressure at the outlet as zero gage pressure where the outlet stream is opened to the atmosphere
i'm not sure if you can assume a fully developed flow you have to check the geometry and the developing length
Why dnt you perform the simulation using commercial package like Ansys, Comsol or open foam ?!!
Yours
Moh'd
Old   May 22, 2016, 15:48
mohammad
you are welcome
Yours
Moh'd
yes, my work has two side, one side is by the commercial codes such as fluent, but another is coding in fortran.
2D Lid Driven Cavity Flow simulation using MATLAB josephlm Main CFD Forum 4 August 17, 2023 20:36
Reynolds Number matching in Cavity flow Endee Main CFD Forum 6 April 20, 2010 04:47
[blockMesh] basic blockMesh : manipulate the lid-driven cavity flow tutorials Lexa OpenFOAM Meshing & Mesh Conversion 2 November 12, 2009 21:15
Supersonic Flow over a Cavity (coodles): Maximum Iterations Exceeded sushant OpenFOAM Running, Solving & CFD 0 April 9, 2009 02:52
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
