Plasma Arc Torch?
Like Tree1Likes
  • 1 Post By ilNannino
Old   February 18, 2016, 10:10
Default Plasma Arc Torch?
anniae is on a distinguished road
Hello;
I am trying to get the isotherms inside a non-transferred arc Plasma torch.
For that, I installed the MHD module, and I tried setting the boundary conditions, but nothing happens when I open it at Post. I can visualize the velocity profile, but when I choose the temperature option, it looks just like I have not used the MHD at all.
Also, the simulation is converging at 30 iterations.
I am fairly inexperient at using MHD or plasma Simulation. Could someone help me? What do I do to generate the current from the cathode to the anode? I set a potential on the Anode in the MHD window, should I also put it on the Boundary conditions window?
Sorry for all these questions, hope someone out there can help me.
anniae is offline   Reply With Quote
Old   February 19, 2016, 02:09
Dario
ilNannino is on a distinguished road
Would you like to simulate only a plasma arc or you want to simulate also a chemical reaction?
anniae likes this.
ilNannino is offline   Reply With Quote
Old   February 23, 2016, 08:35
Hi! Thanks for your reply
At first, I want to get the temperature inside the torch, then the flow in a domain outside it - let's say, a cylindrical reactor.
Simulating a chemical reaction would be interesting, but far too advanced for me at this point.
Old   February 24, 2016, 03:53
Dario
i don't know how to do a plasma simulation.
i'm trying to simulate combustion in a combustor chamber of an engine using the spark model inside fluent. With this model fluent create a group of cells with high temperature (around 2000 K) and the mixture start the reaction.
i think that fluent image the plasma as a spark.
i don't know if my answer help you....
Old   June 8, 2016, 09:05
Tal Eluk
Tal Eluk is on a distinguished road
Hi ilNannino
can you please write an update about your attempts to simulate plasma ignition with the spark model?
(if I understand correctly, you use it as a high temperature heat source for reacting flows?)
Tal Eluk is offline   Reply With Quote
mhd in fluent, plasma
settlingFoam unstable? bendel_boy OpenFOAM Running, Solving & CFD 38 July 8, 2016 05:07
[blockMesh] Another cylinder question bendel_boy OpenFOAM Meshing & Mesh Conversion 5 January 6, 2015 05:09
[Other] mergeMatchPairs with arcs vainilreb OpenFOAM Meshing & Mesh Conversion 1 August 5, 2013 08:11
[blockMesh] multiregion mesh with blockMesh alvora OpenFOAM Meshing & Mesh Conversion 44 July 21, 2013 14:14
[blockMesh] apparently the mesh doesn't want to be created in one direction Maxime Thomas OpenFOAM Meshing & Mesh Conversion 1 August 18, 2012 06:05
