Help in UDF in Blending Function F1 of SST kw |
June 23, 2016, 12:50 |
codenamenone
Rep Power: 10 |
Hello all,
I am trying to write a udf code for blending function f1 of SST kw. However, it seems that variable y which is a distance from the nearest wall is abit hard to define. Is there any way to define this variable? or is there maybe a way to extract the value of blending function to udf? Thank you for your help in advance! Han |
June 23, 2016, 13:12 |
codenamenone
Rep Power: 10 |
Nvm i found it!
July 25, 2016, 03:02 |
Wei Lu
Hi unred486, I am curious about how did you solve this problem.I will appreciate it if you can share your idea in detail.
February 28, 2017, 19:13 |
ali
blending function, sst kw, udf code |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
blending function in cfx SST Gamma Theta model | csui | CFX | 0 | May 14, 2015 17:01 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
In Post-First blending function for BSL and SST | anna | CFX | 2 | September 24, 2011 18:27 |
