Is it necessary to make ''initialization'' by passing from steady to transient |
November 23, 2016, 04:27 |
Onur Özcan
Rep Power: 12 |
Hi all,
I am working on 3d part made heat transfer. I have calculated solver except for energy equation untill 200 iterations. Then, flow was developing and change it from steady to transient. But I thought that i need to make ''initialization'' again to attain lastest flow regimes and regarging their values. But that is why all monitors began from scratch. Is there any information that you are going to share ? |
November 23, 2016, 15:47 |
Rep Power: 18 |
Don't initialise the solution partway through simulations (between steady and transient or otherwise) because you will lose your field values. Initialising the domain is only required when there aren't any values as the solver needs somewhere to iterate from.
November 23, 2016, 23:33 |
Onur Özcan
Rep Power: 12 |
Thank you mate
difference between steady and transient solution? | huangxianbei | CFX | 13 | February 27, 2014 03:20 |
Porous jump modelling: steady vs transient | egge24 | FLUENT | 2 | January 20, 2012 04:05 |
Laminar gas flow under slight suction - transient works but not steady | audrey | CFX | 1 | September 8, 2011 19:43 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
OpenFOAM with IBM AIX | matthias | OpenFOAM Installation | 20 | March 25, 2008 02:36 |
