How to use user-define database file? (.scm)
Like Tree1Likes
  • 1 Post By shanheplus
Old   April 12, 2020, 10:45
Default How to use user-define database file? (.scm)
SHAN He
shanheplus is on a distinguished road
I defined the R134a_liquid material as following.
I referred the FLUENT database "propdb.scm"'s format.
However, it does work?
I don't know why.
Wish for answering me.
Thanks.
(r134a_liquid
  fluid
  (chemical-formula . r134a<l>)
  (density (polynomial piecewise-linear (268 . 1311.6) (268.1 . 1311.3) (268.2 . 1311) (268.3 . 1310.6) (268.4 . 1310.3) (268.5 . 1310) (268.6 . 1309.7) (268.7 . 1309.3) (268.8 . 1309) (268.9 . 1308.7) (269 . 1308.4) (269.1 . 1308) (269.2 . 1307.7) (269.3 . 1307.4) (269.4 . 1307.1) (269.5 . 1306.7) (269.6 . 1306.4) (269.7 . 1306.1) (269.8 . 1305.8) (269.9 . 1305.4) (270 . 1305.1) (270.1 . 1304.8) (270.2 . 1304.5) (270.3 . 1304.1) (270.4 . 1303.8) (270.5 . 1303.5) (270.6 . 1303.2) (270.7 . 1302.8) (270.8 . 1302.5) (270.9 . 1302.2) (271 . 1301.8) (271.1 . 1301.5) (271.2 . 1301.2) (271.3 . 1300.9) (271.4 . 1300.5) (271.5 . 1300.2) (271.6 . 1299.9) (271.7 . 1299.6) (271.8 . 1299.2) (271.9 . 1298.9) (272 . 1298.6) (272.1 . 1298.2) (272.2 . 1297.9) (272.3 . 1297.6) (272.4 . 1297.3) (272.5 . 1296.9) (272.6 . 1296.6) (272.7 . 1296.3) (272.8 . 1295.9) (272.9 . 1295.6) (273 . 1295.3) (273.1 . 1294.9) (273.2 . 1294.6) (273.3 . 1294.3) (273.4 . 1294) (273.5 . 1293.6) (273.6 . 1293.3) (273.7 . 1293) (273.8 . 1292.6) (273.9 . 1292.3) (274 . 1292) (274.1 . 1291.6) (274.2 . 1291.3) (274.3 . 1291) (274.4 . 1290.6) (274.5 . 1290.3) (274.6 . 1290) (274.7 . 1289.6) (274.8 . 1289.3) (274.9 . 1289) (275 . 1288.6) (275.1 . 1288.3) (275.2 . 1288) (275.3 . 1287.6) (275.4 . 1287.3) (275.5 . 1287) (275.6 . 1286.6) (275.7 . 1286.3) (275.8 . 1286) (275.9 . 1285.6) (276 . 1285.3) (276.1 . 1285) (276.2 . 1284.6) (276.3 . 1284.3) (276.4 . 1284) (276.5 . 1283.6) (276.6 . 1283.3) (276.7 . 1283) (276.8 . 1282.6) (276.9 . 1282.3) (277 . 1281.9) (277.1 . 1281.6) (277.2 . 1281.3) (277.3 . 1280.9) (277.4 . 1280.6) (277.5 . 1280.3) (277.6 . 1279.9) (277.7 . 1279.6) (277.8 . 1279.3) (277.9 . 1278.9)))
  (specific-heat (polynomial piecewise-linear (268 . 1327.5) (268.3 . 1328.3) (268.6 . 1329) (268.9 . 1329.8) (269.2 . 1330.6) (269.5 . 1331.3) (269.8 . 1332.1) (270.1 . 1332.9) (270.4 . 1333.7) (270.7 . 1334.5) (271 . 1335.3) (271.3 . 1336.1) (271.6 . 1336.9) (271.9 . 1337.7) (272.2 . 1338.5) (272.5 . 1339.3) (272.8 . 1340.1) (273.1 . 1340.9) (273.4 . 1341.7) (273.7 . 1342.5) (274 . 1343.4) (274.3 . 1344.2) (274.6 . 1345) (274.9 . 1345.9) (275.2 . 1346.7) (275.5 . 1347.5) (275.8 . 1348.4) (276.1 . 1349.2) (276.4 . 1350.1) (276.7 . 1351) (277 . 1351.8) (277.3 . 1352.7) (277.6 . 1353.6) (277.9 . 1354.4)))
  (thermal-conductivity (polynomial piecewise-linear (268 . 0.094308) (268.3 . 0.094174) (268.6 . 0.09404) (268.9 . 0.093905) (269.2 . 0.093771) (269.5 . 0.093637) (269.8 . 0.093503) (270.1 . 0.09337) (270.4 . 0.093236) (270.7 . 0.093102) (271 . 0.092969) (271.3 . 0.092835) (271.6 . 0.092702) (271.9 . 0.092568) (272.2 . 0.092435) (272.5 . 0.092302) (272.8 . 0.092169) (273.1 . 0.092036) (273.4 . 0.091903) (273.7 . 0.09177) (274 . 0.091637) (274.3 . 0.091504) (274.6 . 0.091371) (274.9 . 0.091239) (275.2 . 0.091106) (275.5 . 0.090974) (275.8 . 0.090841) (276.1 . 0.090709) (276.4 . 0.090577) (276.7 . 0.090444) (277 . 0.090312) (277.3 . 0.09018) (277.6 . 0.090048) (277.9 . 0.089916)))
  (viscosity (polynomial piecewise-linear (268 . 0.000268) (268.3 . 0.0002683) (268.6 . 0.0002686) (268.9 . 0.0002689) (269.2 . 0.0002692) (269.5 . 0.0002695) (269.8 . 0.0002698) (270.1 . 0.0002701) (270.4 . 0.0002704) (270.7 . 0.0002707) (271 . 0.000271) (271.3 . 0.0002713) (271.6 . 0.0002716) (271.9 . 0.0002719) (272.2 . 0.0002722) (272.5 . 0.0002725) (272.8 . 0.0002728) (273.1 . 0.0002731) (273.4 . 0.0002734) (273.7 . 0.0002737) (274 . 0.000274) (274.3 . 0.0002743) (274.6 . 0.0002746) (274.9 . 0.0002749) (275.2 . 0.0002752) (275.5 . 0.0002755) (275.8 . 0.0002758) (276.1 . 0.0002761) (276.4 . 0.0002764) (276.7 . 0.0002767) (277 . 0.000277) (277.3 . 0.0002773) (277.6 . 0.0002776) (277.9 . 0.0002779)))
  (molecular-weight (constant . 102.03))
  (reference-temperature (constant . 273.8221)))
khebab likes this.
shanheplus is offline   Reply With Quote
Old   April 13, 2020, 10:26
Default User-Defined Database
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
For user-defined materials, you do not need to write a scheme file manually. You can directly create a new material within Fluent using GUI. If you really want to save it in .scm, say, for sharing with others or for use in other cases, write it from Fluent's Materials Panel. Click on user-defined database and give it a new name. Then select materials from the case to save it in the database. You can write it manually but you have to follow rather strict format.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   February 26, 2023, 02:16
khebab
khebab is on a distinguished road
I have the same issue
I think because Refrigerants have a variable properties !
Hope you answer !
what was your solution for this case !!
khebab is offline   Reply With Quote
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 16:18
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 10:57
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
