Surface Tension Gradient of VOF model
Old   February 22, 2000, 12:05
Default Surface Tension Gradient of VOF model
Ray
Hi! There,
Does anyone know whether the VOF model of Fluent takes account of the variation of surface tension gradient with temperature?
If not, could you forward me some suggestion?
Thank you very much.
Ray
Old   February 22, 2000, 21:45
Default Re: Surface Tension Gradient of VOF model
Burley Wang
Fluent may not provide the funtion, I also met the problem:
1. When you enable the surface tension in the VOF panel, you need to specity the coeffient by yourself.
2. when you use some other fluid (e.g for liquid-air interface), the coeffiecient doesnot change, it idicates that you cannot change the the coefficient as the property of a certain material (however, it may impossible for it involves more than one materail)
3. I also took a look at the UDF reference, it seems Fluent doesnot provide solution of your question.
hope this helpful, good luck!
Burley
Burley
3.
VOF & Variable Surface Tension in FLUENT SeamusTCD FLUENT 13 June 18, 2022 01:51
Surface Tension Test Cases sega OpenFOAM Running, Solving & CFD 2 March 8, 2011 12:19
Inconstant Surface Tension on Interface in VOF Atieh FLUENT 0 February 9, 2007 02:37
Surface tension options for VOF models chapelle FLUENT 4 September 20, 2005 03:49
Turbulence model in flow driven by surface tension Z. ZENG Main CFD Forum 7 April 28, 1999 07:18
