Can't start parallel on NT
Old   March 11, 2000, 06:39
Default Can't start parallel on NT
John Faragher
Has anybody used the parallel version of Fluent on an NT machine? I get error messages when I start it.
I can run the serial version fine but when I try to start the parallel version of Fluent from a DOS window with the command:
fluent 2d -t2
I get a message:
Cannot read directory: c:\fluent.inc\fluent5.3\ntx86\2d_host
Any hints much appreciated, John Faragher
Old   March 11, 2000, 07:40
Default Re: Can't start parallel on NT
tang xin
I has used the following command and can start successfully it on NT: c:\fluent.inc\ntbin\ntx86\fluent -t2
Old   March 13, 2000, 07:07
Volker Pawlik
I once had a similar message. The reason was that no parallel version was installed. But it was with Fluent 5.2.
Old   March 16, 2000, 11:44
LW
I am running a fairly complex 3D model using Parallel solver 5.3 on NT. I can start it in any directory. Make sure you have installed the P-version correctly. If you are including DPM in model, becareful, there is a glich in the code. Good Luck.
Script to Run Parallel Jobs in Rocks Cluster asaha OpenFOAM Running, Solving & CFD 12 July 4, 2012 22:51
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
Unable to start fluent in parallel mode Anand FLUENT 1 January 11, 2009 16:48
Parallel interfom trouble in execution mer OpenFOAM Running, Solving & CFD 6 October 18, 2005 05:45
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 12:00
