Axisymmetric grid
Old   August 1, 2000, 11:38
Default Axisymmetric grid
Chris
I want to run a simple compressible flow problem using an axisymmetric grid. The latter is constructed using Gambit. When I run the 2-D solver it refuses to import the meshed volume I created in Gambit on the grounds that it is 3 dimensional. For the life of me I cannot understand from the help-files how to build either a 2-D grid in Gambit or import a meshed volume as a 2-D grid.
This problem seems rather rediculous but it seems to have this magical power to eat up all my time!!! Help will be much appreciated.
Old   August 1, 2000, 14:24
Default Re: Axisymmetric grid
Shyam Kishor
Gambit requires a 2d model to be in XY plane (Z = 0). So if || z || < 1e-4 every where, it will write a 2d mesh, else, a 3d mesh would be written.
You can "translate" the model in Gambit to make sure they are in XY plane. In case, your model is in XY plane but some of the points/nodes have || Z || > 1e-4, you can use one of the two option below to get a 2d mesh:
1) export a Gambit neutral file (solver = generic) and import this mesh file from a 2d solver
2) Scale down (move/copy form) the model in Gambit such that || Z || < 1e-4 every where. Now mesh exported would be 2d. Once read in solver, scale it up to the original size.
Axisymmetric Grid N. A. OpenFOAM 5 July 2, 2010 10:39
Grid size determination in axisymmetric models krishna086 Main CFD Forum 0 March 31, 2010 08:14
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
Solve axisymmetric by using rectangular grid Atit Koonsrisuk Main CFD Forum 12 February 8, 2001 11:11
Troubles modelling flow through a grid Hans Klaufus CFX 1 June 28, 2000 16:43
