June 19, 2000, 12:55 |
Unsteady Background Job ?
I have been running Fluent jobs in the background (batch). The input file I have used has the form:
rc x.cas (reading the case file) rd x.dat (reading the data file) it 1000 (1000 iterations) wd x1.dat (writing data) . . . . etc. This input file was for steady state cases. I'm trying to run unsteady cases now. Do I need to make any changes to the input file ? I don't see any indication of an unsteady case running, though the case has unsteady solver specifications and a time step setting. I need to run the jobs in the background and can't run them interactively (nice value is higher for interactive jobs on the SGI machine I run the cases). |
July 13, 2000, 13:57 |
Re: Unsteady Background Job ?
You should add another step to run unsteady in the backgroud. For example, add solve/set/ solve/dt/ in your input file. Good luck, Lizheng |
Running unsteady problems in the background | Jie Cui | FLUENT | 0 | February 17, 2005 17:59 |
How to start background job ? | Piet | Siemens | 7 | August 21, 2004 04:35 |
parallel background job using v3.20 | star-user | Siemens | 0 | July 28, 2004 12:37 |
How do I send a job to the background in Unix | Ammu | FLUENT | 2 | July 19, 2004 17:00 |
Input file for Background job | Prateep Chatterjee | FLUENT | 0 | June 10, 2000 17:59 |
