June 6, 2000, 02:33 |
Patching the solution
Hi
Could somebody tell me about patching the solution? I referred the online help in fluent but could not get clear idea about it. Thanks. |
June 6, 2000, 11:18 |
Re: Patching the solution
"Patching" the solution is supplying an initial value for a given property that is different from the initial estimate for steady state. This is really useful for combustion reactions in that if you need a "spark" to light a flame, you can just patch a temperature value high enough for ignition into the cells, and it will ignite it. You initialize the solver first, then the patch option should become available in the menu. Ignition is the only thing I have used it for, though.
June 8, 2000, 15:45 |
For unsteady state heating or cooling, you may be able to use patching to define initial temperature.
Integrated conjugate heat transfer solver in OpenFOAM | hjasak | OpenFOAM Running, Solving & CFD | 172 | April 13, 2023 00:42 |
Solution converged, and then diverge again. | jrg | FLUENT | 2 | April 1, 2013 23:10 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Mesh independent solution | CFX Begineer | CFX | 0 | October 27, 2002 10:54 |
Discussion about Mesh independant solution | Seb | Main CFD Forum | 13 | May 22, 2001 13:37 |
