Faces/ geometry.
Old   June 27, 2000, 12:12
Default Faces/ geometry.
Jack Keays
I have a face in a model which consists of maybe 20 edges and is highly curved. I want to replace one of the edges of the face with 2 different edges. However when I delete the old face and recreate it using the old edges plus the two new replacement edges, the shape of the curve/face is different. The original face was imported as an ACIS file. Has anyone any idea how I can over come this problem? Thank you. Jack.
Old   July 14, 2000, 11:02
Default Re: Faces/ geometry.
Oliver
Hi Jack
I pursume, you created the the geometry in Autocad/Solidworks/or Mechanical Desktop. If you are trying to create a curved surface, you should be using a spline, not a straight edges. 20 edges for a single face, results in a complex face to mesh.
My advice is draw the geometry (curved geometry), by a spline approxiamtion, this should be plenty good enough, until the number of edges curved or otherwise Regards is significantly reduced. Then export the sat file.
Regards Oliver
Old   July 17, 2000, 05:36
Jack Keays
HI,
Thanks Oliver, but I htink my problem is simply that the original geometric parameters which describe the shape of a curved face are lost if u delete that face. IN other words, if you delete a face in Gambit, leaving the edges, and if you then create the face from the same edge, u end up with a different shaped curve when you render the surface. ANy ideas?
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[GAMBIT] create faces inside geometry Lilly ANSYS Meshing & Geometry 11 June 23, 2011 08:34
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Converting Virtual Faces to Real Faces in Gambit gstraw Main CFD Forum 0 June 19, 2009 07:11
[GAMBIT] Problems in forming faces for a complex geometry Lenovo ANSYS Meshing & Geometry 1 June 15, 2009 00:52
