more multiphase modeling questions
Old   September 4, 2000, 19:45
Default more multiphase modeling questions
Shane Gillis
OK, I have the process of multiphase modeling down, no problem. I get good results with 2D analysis, but I am having problems with the 3D analysis. If I create a test case of a cube within a cube and subdivide it in such a way as to be able to mesh the entire volume with hex elements, I can get the system to solve and get good results. However, if I take a test case of a bullet shapped object (since my ultimate goal is to model a ship's hull passing through the water with the atmosphere present) and try to mesh it with hex elements, I can't get it to work. If I try with tet elements, the meshing works, but the system won't solve. Does anyone have any tips or know of any good web resources for Fluent/Gambit modeling/meshing/solving?
Thank you.
Problems with multiphase modeling magnounibo FLUENT 0 April 30, 2009 03:59
experts in multiphase flow modeling in fluent.inc? Asghari FLUENT 0 March 13, 2007 02:46
Multiphase flow modeling Paul CFX 0 August 16, 2004 10:07
Multiphase flow modeling Paul CFX 2 August 11, 2003 09:41
turbulence modeling questions llowen Main CFD Forum 3 September 11, 1998 04:24
