Heat Flux
Old   October 13, 2000, 09:14
Default Heat Flux
Daniel Berglund
I would like some information about the calculation of the heat flux for turbulent flow at a boundary. Eq.6.13-13 in the FLUENT manual describe the heat transfer (flux) when the flow is laminar. Do anyone know the explicit formula for turbulent flow.
Old   October 13, 2000, 16:44
Default Re: Heat Flux
Sung-Eun Kim
Please take a look at Eq.(9.7-5) in Volume 2. Its the temperature law of the wall. What it does is:
- When a wall temperature (T_w) is given, it gives the wall heat flux (q"). - When wall heat hlux is specified, it gives the wall temperature.
Sign of Heat Flux at wall Kyung FLUENT 2 February 26, 2016 16:25
Calculating heat flux hugo17 OpenFOAM Post-Processing 4 May 27, 2015 12:47
Variable name for heat flux peterle CFX 4 February 13, 2014 02:21
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
Heat Flux Wall Boundary Confusion. Joee FLUENT 1 August 21, 2010 12:20
