UDF for pulsing flow.
Old   February 1, 2001, 10:19
Default UDF for pulsing flow.
J. Keays
Would anyone have a udf that allows me to place a pulsatile flow at the exit from my pump, which is also elliptical in profile? I am modelling a single balded pump, so there is a large pressure pulse in each revolution. I have successfully implemented a udf to allow for this pulsing effect, but I would like ot make it so that the velocity profile is parabolic at the exit rahter than flat as is the case with the udf. So, how do I implement a parabolic profile on to a pulsing flow? Needless to say, the problem is been run unsteady.
thanks,
J.
UDF to measure Mass Flow Rate a.lynchy Fluent UDF and Scheme Programming 31 October 4, 2018 14:10
UDF for transient pressure inlet, mass flow check at nozzle exit and volumetric heat kokoory FLUENT 0 August 17, 2011 02:07
How to define mass flow rate using UDF? SAMUEL FLUENT 3 December 25, 2004 00:36
How to define mass flow rate using UDF? SAMUEL FLUENT 0 December 16, 2004 02:55
UDF for multiphase flow ROOZBEH FLUENT 3 April 7, 2004 17:54
