January 16, 2001, 05:03 |
Gambit: versions compatibility
Hi gambit users, I need your help. I have created a geometry with Gambit 1.3 (by importing a Parasolid) but I need now to read it on Gambit 1.2. The problem is I get an error message: "this database was not properly closed". I have resaved the session with the version 1.3 and tried again with 1.2 but the error is still displayed. Does any of you know how to make the two versions compatible?
Any information is welcome, Regards. |
January 24, 2001, 10:31 |
Re: Gambit: versions compatibility
You can read a dbs file from an older version into a new one, but not the other way around.
You should export the geometry from Gambit1.3 as an ACIS file, and then import it back in Gambit1.2. Please make sure to specify the ACIS version as "5.0" during export in Gambit 1.3, to make it compatible with that of Gambit 1.2. |
January 31, 2001, 08:27 |
Thanks for the advice. I tried and it worked fine.
Regards. |
Gambit 2.3.16, Xming or Exceed...HELP! | bambam3417 | FLUENT | 10 | May 7, 2010 12:39 |
Gambit compatibility problem with VISTA | armin | FLUENT | 10 | February 19, 2008 21:01 |
Gambit -dev X11 doesn't work | Ervin Amet | FLUENT | 0 | October 28, 2007 08:33 |
Athlon 64 Gambit Compatibility? | Derick | FLUENT | 3 | January 17, 2006 17:28 |
Gambit OpenFoam compatibility Grid conversionquality | ghanshyam | OpenFOAM Pre-Processing | 0 | September 20, 2005 04:13 |
