July 7, 2001, 12:56 |
liquid and gas flow
Dear;
I want to do calculations of dispersed gas phase in liquid phase and i want to account for the sizes and shapes of the bubbles when break up and coalescence occur. My be there is two methods: 1) Particles in the dispersed phase can be divided into several size groups and each of these size groups can be treated as separate phase using Fluent 4.5 multiphase eulerian model. 2) Application of population balance using the models accounting for the break up (Luo and Svendsen, AICHE J., May 1996) and coalescence (Prince and Blanch, AICHE J., Oct. 1990). My question is to know if it 's possible to use UDF functions (additional scalar transport equations) for bubble coalescence and bubble break up with only two phase flow, the continuous liquid phase and the gas dispersed phase in fluent 4.5 or fluent 5.5 ? Thanks great |
July 9, 2001, 03:22 |
Re: liquid and gas flow
When I read your request, I instantly thought at an article I read in the FluentNews (Newsletter, Vol. 9, Issue 2 Fall 2000/Winter 2001, pp. 6). It is dealing with the Breakup and Coalesence Modeled through User Defined Functions. If you want, I can fax that article to you (1 side).
July 9, 2001, 09:48 |
Hi Peter;
If it is possible to send me the article in question, I will be you thankful. My greetings |
July 10, 2001, 09:52 |
Thanks Peter
Thanks Peter
Best regards |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
What is the difference between liquid reactive flow and gas reactive flow? | James | Main CFD Forum | 6 | May 15, 2009 12:14 |
Gas Liquid flow in a packed column | Rakib | FLUENT | 8 | June 18, 2002 01:58 |
