about temperature rising in fluent5.4.8
Old   July 7, 2001, 09:25
Default about temperature rising in fluent5.4.8
Devy
Now I am studying TUT 8.in fluent mannul, "Chemical Mixing and Gas Combustion". I change the air as to oxygen in the boundary of air-inlet,and I don't change the other model.
When the solution is converged,I found the temperature rised to 5000k.And this is not true.
I've tried everything I can imagine!!!
Would you give me some advice?
Thanks a lot, in advance......
Devy 2001.7.7
Old   July 9, 2001, 11:08
Default Re: about temperature rising in fluent5.4.8
AJ
Is the temperature lower than expected? Try setting limits to higher temperature. Default maximum is 5000K. If temperature is more than that you give higher value as default maximum. AJ
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 06:36
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Pressure rising with temperature Koranten FLUENT 0 August 19, 2009 05:57
about temperature rising in fluent5.4.8 Devy FLUENT 2 April 9, 2001 07:05
about temperature rising in fluent5.4.8 Devy FLUENT 2 April 4, 2001 11:32
