Porous Media
Old   August 13, 2001, 05:40
Default Porous Media
Armin Gips
I have an 2-d object with a porous zone in it. First I calculate a solution without the porous media (k-epsilon turbulence modell;two layer zone). All residuals are lower than 0.003 and all monitors are constant. Then I switch on the porous media. Now the residual of continuity does not decrease (contstant value1,2) and the residual of k increases. (all other decrease and the monitors are constant). What can I do? Thanx Armin
Old   August 14, 2001, 03:43
Default Re: Porous Media
chiseung
In my opinion, you should check your b.c. again , especially porous media. There are many cases that residual history of continuity doesn't decrease when B.C.s are not properly set.
P.S : If I were in your shoes, I would solve that problem switching on the porous media without k-e model. Then, I would turn on the viscous model and try to converge by changing relaxation factors.
Old   August 15, 2001, 02:27
Armin Gips
It does not work. I checked my B.C., and try to get a solution without porous media and without Turbulence. Then I switch on the porous media and the residuals of continuity increased, and now they are constant. What else can I do?
Yours
Armin
Old   August 15, 2001, 02:36
chiseung
I meant...(1) first, "with porous media" and "without turbulence" (2) second " with porous media" and "with turbulence"
Multiphase Porous Media Flow - Convergence Issues VT_Bromley FLUENT 7 May 14, 2020 16:34
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 04:09
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 10:34
species mass source in porous media ? PK FLUENT 0 February 16, 2007 11:12
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 15:16
