Fidap files management
Old   September 13, 2001, 06:37
Default Fidap files management
Federico
I"ve just started using Fidap. I"ve two problems : 1) Savings model files + boundary conditions (when i open a previously saved session, i can-t no longer see the b.c.). 2) I can't manage the convergence criteria (i want to go on iterating also after convergence has been reached)
Can anyone help me? Thank you
F.Brighi
Old   October 3, 2001, 10:15
Default Re: Fidap files management
Jaydeep Kulkarni
1. When you run a job the very first time with a partcular identifier, you should use the flag -new to start Fidap. In order to save the existing session, you will "END" out of Fidap. The next time you want to open up the existing database, don't use the -new option. Then, Fidap will recognize the previously entered b.c.s etc. If you still use the -new option to open up an existing database, Fidap will ignore whatever had been previously entered into it.
2. I am not sure what you mean by "I want to go on iterating after the convergence is reached". Fidap will (ans should!) stop when the convergence is reached. You can tighten the converence by using the velconv/surfconv keywords and schange = 0 on the solution card. See the command documentation in the FIPREP manual.
UDF issue MASOUD Fluent UDF and Scheme Programming 14 December 6, 2012 13:39
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 10:46
