MODELISATION OF SEA WATER DENSITY CHANGES
Old   August 14, 2001, 07:10
Default MODELISATION OF SEA WATER DENSITY CHANGES
Alex Fabregat
Hi all!
We need some advice on how to deal with density changes in the simulation of effluent discharges in sea water. Does anyone know the UDF to model the density of sea water as a function of temperature and salt concentration?
Thanks a lot!
Old   August 16, 2001, 09:32
Default Re: MODELISATION OF SEA WATER DENSITY CHANGES
Ola Nordblom
(1) The technical support at Fluent told me that a User-Defined-Function (UDF) can be used to define e.g. a temperature and concentration dependent density, as long as the density variations within the fluid are small. (2) Enable a User-defined-scalar for the salt concentration and solve the heat equation for the temperature. (3) The appropriate UDF for the calculation of density, C_R(c,t), is the DEFINE_PROPERTY. In this function you can easily get access to the temperature and the user-defined-scalar values (salt conc.) in all cells, see the UDF manual. (4) The Sea Water Equation of State is defined in UNESCO International Equation of State (IES 80), see e.g. http://fermi.jhuapl.edu/denscalc.html, the matlab routines on http://www.marine.csiro.au/~morgan/seawater/ , might also be helpful as a reference when you define your UDF.
Ola Nordblom
Old   June 11, 2012, 01:57
Arrow Modeling of Sea States in ANSYS-13
Nazir
Nazir426 is on a distinguished road
hi every one.
i want to model the sea states in FLUENT-13 but i have no idea of how to model it? Can anyone share with me the Basic tutorials?
waiting for yours positive responses...........
Nazir426 is offline   Reply With Quote
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Warning 097- AB Siemens 6 November 15, 2004 04:41
variable density water Atit Koonsrisuk CFX 2 July 24, 2003 03:07
Damage to Sea Wall due storm water run off HELP!!! Robertson,W. Main CFD Forum 1 June 8, 2002 10:06
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
