Fidap memory problem?
Old   September 29, 2001, 14:33
Default Fidap memory problem?
Fred
When I use Fidap on particulary strong cases (such as 3d or 2d thermofluidodynamic simulations) the fisolv runs for about 60-70 iterations, then he stops all activities (without reporting a convergence o a divergence to be happened, he reports no message) and when i try to start fipost, to see the solution he has reached in this few iterations, fidap shows an error message, saying then only mesh plot is possible. Could anyone help me in this strange problem? (is it a problem of memory? my system has 1 Gb for Ram and more than 1 Gb of HD, and it's a Pentiun II).
Old   October 3, 2001, 10:04
Default Re: Fidap memory problem?
Jaydeep Kulkarni
1Gb of RAM and 1Gb of HD should certainly be sufficient for almost all 2D problems. You can run Fidap in the exec(datacheck) mode and see in the FDSTAT file how much memory it would need to run the problem. It is the number in front of "Minimum core memory required during the solution phase" multiplied by 4. Otherwise, when the problem is running (before it crashes), you can look up the task manager to find out how much memory it is actaully taking.
Are you running Fidap locally on the PC? One needs to make sure that there are no network related problems. Is it NT or Windows 2000?
Old   October 3, 2001, 12:33
Fred
Thank-you for your response, on monday i'll try doing as you tell. I'm running fidap on local computer (Pc with Windows NT, i'm a part of a net, but Fidap is on local). With a 2d problem the only fluidodinamic iterations are good (he converges to a right solution), when i pass to thermo-fluidodinamic fisolv crashes after few iterations....it may be an error in my fidap usage however...
Fred
User Defined Memory Problem Melih FLUENT 17 February 21, 2020 07:43
Problem in Memory by running blockMesh mamaly60 OpenFOAM Running, Solving & CFD 5 August 11, 2016 15:27
Virtual memory problem with parallel runs Ali (Ali) OpenFOAM Running, Solving & CFD 21 May 25, 2011 04:27
RAM memory problem alpha Main CFD Forum 8 February 12, 2008 11:07
Memory problem in fluent freeman FLUENT 3 February 3, 2006 10:05
