hexa/wedge interface
Old   September 5, 2001, 12:24
Default hexa/wedge interface
Mark
Hi
I have a mesh with hexas which can sometimes be next to two wedges. i.e the quad face of the hexa joins the two triangle faces of the wedges. How can I get fluent to cope with this set up. It works fine in STAR-CD !! Can I simply call each of the faces in question an interface boundary ??
Regards
Mark
Old   October 4, 2001, 21:26
Default Re: hexa/wedge interface
the daddy
There is no easy solution but there is a workround. What you need to do is collect all your faces which are not matching into 2 groups, one for the hex faces, one for the tri faces. Then set BC type of each zone to "Interface" Then go into Define --> Interfaces (I think). And make the two zones a pair of interfaces.
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
