Variable wall velocity
Old   November 8, 2001, 23:09
Default Variable wall velocity
Sambasivam
Hi, I have a query. In fluent, there is an option for moving boundary but the velocity should be constant. Is there anyway to assign variable velocity through an UDF? Thanks
R. Sambasivam.
Old   November 21, 2001, 21:18
Default Re: Variable wall velocity
david
could you describe more what you really want to do ?
DC
Old   November 21, 2001, 22:23
Sambasivam
Thank you for your response. See, Fluent has a provision to assign either linear or angular velocity to the wall/boundary. But this velocity should be a constant not a function of time. But I need to specify the velocity as a function of time. Say, I want to simulate a vibrating wall whose velocity varies sinusoidally. How can I approach this problem? If you can throw some light on this, I would be thankful to you.
Warm regards,
R. Sambasivam.
impose oscillating wall velocity IvanCFD FLUENT 0 May 13, 2010 08:53
velocity inlet vs. moving wall boundary condition Jane Leous Main CFD Forum 0 September 12, 2008 12:42
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
maintaining a logarithmic velocity distribution Morten Andersen CFX 1 January 8, 2007 11:37
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
