liquid particle track and flow rate
Old   November 28, 2001, 10:16
Default liquid particle track and flow rate
Tim
In Inject option of Fluent, the flow rate of the liquid seems not to affect the particle motion pattern. Only the size of the particle diameter changes the particle track pattern.
Is this true or should more things be taken care of in Inject menu?
Thanks in advance.
Tim
Old   November 28, 2001, 21:41
Default Re: liquid particle track and flow rate
Jin-Wook LEE
Check that 'Interaction with particle phase' is 'ON' or 'OFF'. If, 'OFF', flow rate of particle can not affect the trajectory because the assumption is that particle does not change the flow field. In this case(OFF), of course, particle trajectory is dependent of the particle diameter.
Sincerely, Jinwook
how can I get the unsteady flow pathline,to use particle track? pp8997 FLUENT 0 January 23, 2010 22:11
question about particle track pengfei FLUENT 1 November 20, 2009 06:33
may i import flow field data to do particle track? Hao FLUENT 8 April 29, 2008 08:22
Laminar Flow and Particle Track: Inconsistent? Domenico FLUENT 0 February 20, 2007 14:49
Laminar Flow and Particle Track: Inconsistent? Domenico FLUENT 0 February 20, 2007 14:47
