Defining an Unsteady Flow
Old   December 5, 2001, 09:49
Default Defining an Unsteady Flow
Paul Devereux
As a relatively new user of Fluent, I was hoping that somebody would be able to explain the basics of creating unsteady flow in Fluent. I am attempting to model blood flow through various geometries.
Old   December 6, 2001, 14:35
Default Re: Defining an Unsteady Flow
jim clancy
Paul, Go to the main menu..select Define>>Solver, in this panel you can set your solver to unsteady...BUT..dont forget that blood is NON-NEWTONIAN fluid, where the NS slover cannot be applied accurately..good luck
Old   December 8, 2001, 04:48
santosh
Paul, if you want some more help you can look into help>>basic physical models>>time dependent simulations.you will get all the inputs you need for modelling unsteady flow.
Unsteady simulation of flow past wheel Tom FLUENT 8 January 18, 2006 10:54
Unsteady flow in FLUENT Vidya Raja FLUENT 2 November 2, 2005 16:29
Unsteady Boundary Layer Flow Wen Long Main CFD Forum 0 July 29, 2002 23:08
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
computation about flow around a yawed cone Tylor Xie Main CFD Forum 0 June 9, 1999 07:33
