January 18, 2002, 07:16 |
Mixing plane geometry definition
I am confused about the mixing plane geometry definition in Fluent. As you know there are 2 options : Radial and Axial. If the mixing plane is a cylindrical surface with an axis coincident with the axis of rotation, is this a radial mixing plane ? Or, if the mixing plane is a flat surface normal to the axis of rotation is this an axial mixing plane ?
The users manual P.16-30 states that: A Radial geometry signifies that the information at the mixing plane interface is to be circumferentially averaged into pprofiles that vary in the radial direction. This is the case for axial-flow machines, for example. Could anyone enlighten me on this issue, and help me to have a correct understanding of the mixing plane geometry definition. Thanks Hbet |
Problem with Mixing plane | Mitpostdoc | FLUENT | 0 | July 26, 2011 14:31 |
Mixing plane for centrifugal compressor | Mitpostdoc | FLUENT | 0 | March 24, 2011 17:27 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
Definition of Plane pointer | Julian K. | FLUENT | 0 | January 5, 2009 10:24 |
Error in flux at Fluent´s mixing plane calculation | ales | FLUENT | 0 | February 9, 2005 04:48 |
