new user - need help
Old   January 17, 2002, 10:49
Default new user - need help
Kirsten
hi, im an engineering student from ireland. i'm using fluent for my final year project. i cant find any books on it in the library, and i cant afford to buy one. i know basically how to use it, but i could really do with some information about what way to change the default settings to make the solution converge quicker (or converge at all), or to make the results more accurate. does anyone want to help me?
sort of :
if the velocity is above 200m/s, increase the third default number in the spalart-allmaras turbulence model. (or whatever)
or does anyone know of a website where i could find such information?
the model i'm working on is an axisymmetric, incompressible (more or less) jet.
one particular thing i cant figure out. my lecturer suggested i solve the problem using a coarse mesh first, and mess around with the controls to see how to make it converge. i actually managed to get the solution to converge for the coarse mesh, than used the exact same controls for the dense mesh, but it completely diverged! any idea why? the two meshes are as similar as i can make them, except for the density.
thanks, kirsten
Old   January 17, 2002, 11:27
Default Re: new user - need help
Atholl
Sorry I can't help you more specifically, but assuming you have an academic licence for Fluent, you can give a support engineer an email with your queries. That, together with any replies you get here should see you right!
Old   January 17, 2002, 16:54
Vasily
Hi, i can recomend one website galaxy.sdsu.edu/fluent/fluent5/tg/html/main.htm but, unfortunately it almost duplicates the manual As to your problem with convergence using finer mesh, try to decrease time step.
Old   January 17, 2002, 19:51
jim clancy
Hi kristen, I think you must use compressible flow for the jet flow. your assumption is totally wrong for incompressible jet flow.
Old   January 19, 2002, 02:11
Anindya
As jim said, your flow should be considered compressible as flows with mach number less than 0.3 are considered incompressible, whereas in your case it is 0.6 . You have to play with your mesh and turbulence models a little bit to see if you get convergence.
collect User Experience about CFD softwares dxw_CFD Main CFD Forum 12 October 24, 2011 22:08
user routine, user funcion, or fortran compile effect on the memroy? princeps11 CFX 1 May 13, 2009 18:37
CFX 10 User Routine NOT in Fortran Andre CFX 14 August 8, 2006 23:03
particle user routines Felix CFX 1 July 24, 2006 12:32
User Surface, Calculator Christian Bruzzese CFX 3 November 15, 2005 10:13
