Mass,Momentum,Energy source!
Old   March 16, 2002, 13:53
Default Mass,Momentum,Energy source!
S. Ferraris
Hi !
I have same problems with a mass,momentum and energy source within the interior of the fluid.
I coulndnt get the velocity and the direction required in the fluid.
Can anybody help me.
Thank you in advance
Sergio Ferraris
Old   March 17, 2002, 18:35
Default Re: Mass,Momentum,Energy source!
Greg Perkins
What is the problem!!!!
Source not working, not giving expected result???
Greg
Old   March 18, 2002, 07:25
S. Ferraris
thank you! Yes .
I did not have what i hoped. I put x(kg/m3) and x (n/m3)( Y direction for example) and first at all i didnt get velocity in Y direction only, i had a component in X direction , also different mass rate was obtained. I used different numbers but i could not make it works.
Sincerely.
Thank you
Sergio Ferraris
Old   March 18, 2002, 16:52
Greg Perkins
You will need to do two things:
1. add a total mass source (kg/m3-s) to the cell 2. add momentum terms to the X and Y velocity (kg/m2-s2).
Try them independently to see how they work!
Greg
Old   March 19, 2002, 12:53
S. Ferraris
Thank for you answer.
I tried to set up the momentum and mass source in that way to simulate an puntual velocity inlet. So in this way i didnt do the mesh again , but i finally realise that is not a good idea. Do you know same way to do that ?
Best regards.
Sergio.
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
