duplicate nodes in mesh
Old   May 1, 2002, 18:05
Default duplicate nodes in mesh
Sunil Vijay Sathe
Hi all, Is there a way generate a mesh which has duplicate nodes on some boundary. e.g. perpendicular flow past a flat plate. The thickness of the plate is neglected, so to capture the discontinuity in the velocity and pressure we have to have two nodes at the same point on the plate. one will be facing the upstream and other will be facing the downstream. Can gambit generate such meshes? Sunil.
Old   May 2, 2002, 23:00
Default Re: duplicate nodes in mesh
Jin-Wook LEE
Yes, Gambit can.
1) Generate Volume : your computational domain
2) Generate Face : your flat plate
3) 'SPLIT' Volume by the Face
4) Set the face as wall
Sincerely, Jinwook
Old   May 3, 2002, 11:07
Sunil Vijay Sathe
I tried it. I could not find out how to specify the face as wall. Can you tell me that? Also, is it possible to do the same in 2D? Have duplicate nodes along an edge? Lastly, instead of volume geometry I have a surface mesh of the volume and instead of the plate geometry I have a surface mesh of the plate, is there a way to generate a similar volume mesh (i.e. duplicate nodes?) from these surface meshes?
Old   May 5, 2002, 20:37
Jin-Wook LEE
1. How to specify the face as wall ? : OPERATION --> ZONES --> SPECIFY BOUNDARY TYPE
2. Is it possible to do the same in 2D ? : YES. SPLIT FACE WITH FACE
Sincerely, Jinwook
[tgrid] duplicate nodes - not really gskillas ANSYS Meshing & Geometry 1 February 9, 2015 05:09
[ICEM] how can i delect the duplicate mesh line and nodes in interface between quad and tri? snailstb ANSYS Meshing & Geometry 10 September 26, 2013 08:19
ICEM periodicity nodes after mesh generation... Andrey CFX 8 May 1, 2012 17:11
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
