Is there a memory limitation in NT?
Old   May 13, 2002, 05:05
Default Is there a memory limitation in NT?
Erwin
Has anybody run models of over 2GB on a NT machine?
I have been told that because of the 32-bit addressing space, Fluent cannot handle problems of over 2^(31) = about 2 GB when running on a Windows NT system.
Would Windows XP solve that problem?
Old   May 13, 2002, 17:09
Default Re: Is there a memory limitation in NT?
Jim Clancy
According my experience with FLUENT on Windows NT platform, I can say: If you are looking for higher memory you should go for LINUX ...Good Luck
Old   May 13, 2002, 17:10
Jim Clancy
According to my experience with FLUENT on Windows NT platform, I can say: If you are looking for higher memory you should go for LINUX ...Good Luck
Old   May 13, 2002, 21:25
Keil
Windows XP cannot solve this kind of problem like Windows NT. In my experience, WindowsNT and XP were not good for big calculations. It was very unstable. I recommend Linux,too .
But if you have SMP machine with 4GB memories, FLUENT cluster parallel can use all 4GB memories.
Try "fluent 3d -pnet". Of course you need the licenses.
Old   May 14, 2002, 04:16
Volker Pawlik
As far as I know the actual LINUX-Distributions have the same limitations as NT, since they are 32-bit systems too. There shall be a 64-bit version in connection with the new IP64 Intel Chip. But I do not know whether fluent already offers a 64-bit Linux-Version.
Hence at the moment the only remedy is to use an UNIX-System which is unfortunately very expensive OR to work only in parallel mode with enough CPUs AND lincenses in order to avoid exceeding the 2 GB limit (with all the difficulties and bugs of the parallel version).
Old   May 14, 2002, 09:24
Erwin
OK. Thanks guys.
How to optimize the memory usage when using FEM vasilis Main CFD Forum 11 August 24, 2009 23:57
Memory error? Young CFX 3 September 30, 2008 11:33
CFX CPU time & real time Nick Strantzias CFX 8 July 23, 2006 17:50
Run-Time memory conifguration Error Graeme CFX 1 February 20, 2006 23:04
Is there a limitation of memory size for UDFs? Chen Fangzhi FLUENT 3 August 19, 2003 02:46
