May 23, 2002, 21:21 |
How to obtain mass flow rate of one phase
Who can tell me how to obtain the mass flow rate of one specific phase through one boundary in a multiphase simulation? I know following three methods: (1)In text command: report/mass-flow (2)In menu: Solver>Monitor>mass flow rate (3)In menu: Solver>Monitor>flow rate>choose phase vilume fraction as the variable. I tried above three methods, and the results are different. Which one should be correct? Also, I hope to export the mass-flow-rate vs time data to a file. How can I realize this? Thank you very much. -Dejun Jing |
mass flow rate not conserved in turbomachine, interface defined wrong? | wildli | FLUENT | 3 | September 15, 2022 12:19 |
Mass flow rate: calculation v/s computation | beguxa | FLUENT | 5 | December 2, 2018 21:02 |
UDF to measure Mass Flow Rate | a.lynchy | Fluent UDF and Scheme Programming | 31 | October 4, 2018 14:10 |
How to change from mass flow to volume flow rate | stanley | FLUENT | 1 | February 2, 2007 06:44 |
mass flow rate of a dispersion phase | Paul | FLUENT | 1 | February 25, 2002 23:19 |
