UDF
Old   July 13, 2002, 01:13
Default UDF
Moh
I followed the steps in the UDF manual, chapter 1. I cut and paste one of the UDF codes in that manual (udfexample.c on page (1-10) PDF UDF manual- to specify a pre-defined function for the inlet velocity).
I still get an error message after compiling the source code as interpreted UDF
the error is not clear for me. I'm sure that the .c and the .cas files are at the same directory and I read the case file before the compilation. please tell me what I have to do? thanks for your help in advance
Old   July 15, 2002, 13:06
Default Re: UDF
Duc
Moh,
Depends on what you paste the codes on? is it just a text editor? and also is it under the same platform as Fluent? Also what is the error message?
Old   July 16, 2002, 13:06
Default Re: UDF
Moh
thank you. Actually I copied and pasted it again then it worked. Thank you for you kind help
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
