transitional cavity flow
Old   August 12, 2002, 04:50
Default transitional cavity flow
elif
Hi, I have some experimental data on transitional cavity flow (Re~3000-12000). Recently I tried to model the problem with Fluent 5.3 utilizing k-e (RNG, standart) with wall function or two-layer zonal models. Experimental data shows the existence of two bubbles insides the cavity. However, despite the fact that I have tried many grid configurations, I could obtain only one recirculating bubble. It seems that the problem emanates from the transitional flow regime. Could you please comment on possible solutions on this problem? Thanks in advance.
Urgent: Unsteady 3-D supersonic cavity flow Min-Sung Kang FLUENT 3 April 6, 2014 09:50
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
[blockMesh] basic blockMesh : manipulate the lid-driven cavity flow tutorials Lexa OpenFOAM Meshing & Mesh Conversion 2 November 12, 2009 21:15
Supersonic Flow over a Cavity (coodles): Maximum Iterations Exceeded sushant OpenFOAM Running, Solving & CFD 0 April 9, 2009 02:52
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
