August 20, 2002, 05:23 |
about post-processing of fluent
Hi:
Now I am computating a minisize centrifugal blood pump with fluent 6.0.I can get contours of pressure,velocity and others.I want to know the shear sress in the pump ,but i cannot find it .Who can tell me how to get the shear sress in fluent? regards! |
August 20, 2002, 17:58 |
Re: about post-processing of fluent
If you look under the wall fluxes option you can select either shear stress or skin friction coefficient.
August 20, 2002, 21:33 |
Rob:
I still can't find it .In my fluent 6.0,I only find mass flow rate,total heat transfer rate and radial heat transfer rate through report- fluxes.Maybe i didn't catch what you said. Can you give me more details? Thank you! |
August 23, 2002, 14:35 |
Hi Rob,
Please find it through display -->wall fluxes -->wall shear stress hope this helps u Regards, sri |
August 27, 2002, 04:50 |
Hi sri
In my fluent6.0,I still cannot find the path as you said.In 'display' i only find grid,contours ,vectors,path lines ,particle tracks and others.What's wrong? Thanks for you help! |
August 27, 2002, 11:20 |
hi lingo,
i am sorry for not being specific. the path is display -->contours -->wall fluxes -->wall shear stress hope this helps you. |
August 27, 2002, 21:34 |
sri: I find it,thanks for you help!
Ansys Post Processing | Brian_P | Main CFD Forum | 0 | March 4, 2010 16:05 |
Surface Post Processing | Graham | Main CFD Forum | 0 | November 11, 2009 14:49 |
Post processing in FLUENT | praveen.jpk | FLUENT | 1 | September 10, 2009 01:58 |
Different in fluent result after post processing | Niles | FLUENT | 0 | August 14, 2008 04:28 |
post processing in CFD | MANISH BHARGAVA | Main CFD Forum | 0 | October 17, 1998 20:51 |
