Parallel Processing for students
Old   September 23, 2002, 16:31
Default Parallel Processing for students
Chetan Kadakia
Hi. I am using a Fluent with a University License. Does anyone know if I have parallel processing capabilities? And if I do, how do I work it?
Old   September 24, 2002, 03:24
Default Re: Parallel Processing for students
pp
Look in your license file if you have parallel feature (fluent-par).
BR
pp
Old   September 24, 2002, 03:54
Piran
Is that with a "locked" license for one machine? Because we have a server with floating licenses and can use parallel processing and the license file does not contain fluent-par. If you have more than one license you should be able to use parallel processing, because every processor will simply use up a license.
Old   October 1, 2002, 12:13
Shankar
And how do we do that Piran, parallel processin with more than 1 license?Thanks. Shankar.
Old   October 1, 2002, 12:58
Piran
If you have a multi-processor machine or a network of pc's you can use the parallel solver. You set up the case file as usually, but at the end you partition the grid. You save the case and restart Fluent but in parallel mode. Every processor starts a Fluent session (hence you use up one license per processor) and takes care of a certain part of the grid. You should check the manual because it differs a lot depending whether you use a smp-machine or a network and which platform you are running under.
Old   October 1, 2002, 13:09
Shankar
Thanks Piran Its a network of Unix machines(sun operating sys) Shankar.
Old   October 9, 2002, 09:05
Jimmy
Fluents licences is defined for a number of PROCESSORS, so if you want t o use it in parallel you need to acquire as much licences as processors you have.
Parallel processing of OpenFOAM cases on multicore processor??? g.akbari OpenFOAM Running, Solving & CFD 31 November 1, 2017 09:25
multiphase solver - parallel processing - GAMG thibault_pringuey OpenFOAM Programming & Development 2 August 27, 2013 22:03
HP MPI warning...Distributed parallel processing Peter CFX 10 May 14, 2011 06:17
bubbly flow and parallel processing mvee FLUENT 0 September 12, 2007 05:08
About parallel processing in Linux tuks CFX 10 August 8, 2005 08:22
