compressible flow in compressor
Old   October 19, 2002, 21:52
Default compressible flow in compressor
rahmat
Hi all
Does Flient.6 could make a model of flow through kompressor's impeller???
Rahmat
Old   October 21, 2002, 01:33
Default Re: compressible flow in compressor
rahul
Fluent can model compressible flow through impeller. You have to activate ideal gas equation in materials panel. Use MRF model to model ratating flows.
Old   October 21, 2002, 08:18
rahmat
I have tried, but I don't know how to make it to be convergence? segregated or coupled I should choose?
May I ask you a question? What kind of boundary condition should I set? I want to make a characteristic curve of the compressor; Can I make a variation on pressure ratio at a constant rotation speed?
Rahmat
Old   October 23, 2002, 13:13
rahul
If you choose coupled solver, energy will be automatically be activated. For getting convergence, you have to lower under-relaxation parameters. use 0.3 on velocity, 0.2 for pressure & 0.8 for energy.
Another way to reach convergence criteria is to solve the problem treating incompressible. (use segregated solver). The flow field obtained in this manner will be treated as initial guess for subsequent compressible flow simulation.
Typically, mass flow BC should be used with compressible flow. If you didn't get convergence, try velocity inlet & pressure outlet.
Incompressible and compressible flow. Confused student. Main CFD Forum 27 March 18, 2017 12:25
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 02:10
help with compressible flow BC's (need subsonic flow) meangreen Main CFD Forum 5 July 24, 2010 13:16
Compressible Fluid Flow in COMSOL Multiphysics BBG COMSOL 1 November 19, 2008 14:05
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
