Shaft moment for turbomachine's labirynth seals
Old   February 21, 2003, 09:35
Default Shaft moment for turbomachine's labirynth seals
Stanislav Pagur
Hi evrybody,
Can I get an advice or reference with force moments for rotor/stator in turbine labirynth seals?
The main problem is lack experimental data or empirical formulas.
BR, Stanislav
Old   February 21, 2003, 11:38
Default Re: Shaft moment for turbomachine's labirynth seal
cjtune
I remember being able to get imformation like these for bearings from catalogues so you'd do best to contact your hardware suppliers/manufacturer.
Old   February 26, 2003, 07:30
Stanislav Pagur
Thank you, but I'm hardware(steam turbine) designer.
This task (shaft moment in seals) is absent in available papers and prescribed industrial algorithms (I mean Ukrainian and post-USSR). May be this problem was solved Western or Asian engineers?
Moment Report from Fluent Thanathat FLUENT 4 December 11, 2014 00:42
Force can not converge colopolo CFX 13 October 4, 2011 22:03
UDF extern variable - mean time moment coefficient enry Fluent UDF and Scheme Programming 0 November 14, 2009 06:56
UDF extern variable - mean time moment coefficient enry Fluent UDF and Scheme Programming 0 November 14, 2009 06:51
viscous moment Thierry FLUENT 0 April 8, 2003 05:43
