combustion of Aluminum particle in oxidant-rich ga
Old   March 3, 2003, 03:00
Default combustion of Aluminum particle in oxidant-rich ga
Devy
Now I want to use fluent5.4.8 to simulate combustion of Aluminum particle in oxidant-rich gas. But there are only some examples about Pulverized Coal combustion and liquid fuel combustion in fluent.These mean only the reactant is particle. Now in my problem,not only the reactant but also the product of combustion is particle. Do you have some cases about this?Would you like to give me some cases?
Thank you for your help.
Old   March 3, 2003, 06:06
Default Re: combustion of Aluminum particle in oxidant-ric
Stanislav Pagur
Hi, I think you would use UDF to define rate of surface oxidation
4Al(s)+3O2(v)= 2Al2O3(s) +Q
first - try to build model of oxigen diffusion through Al2Os core (is this core solid or liquid in your case?)
second - note that under extra high temperature aluminium can react with nitrogen as wel as with oxigen
2Al(s)+ N2(v) = 2AlN(s)
third - be shure to use valid heat capacity functions to get valid enthalpy at temperature of reaction.
good luck,
Stanislav
Old   March 3, 2003, 22:01
Devy
Thank you for your help. But in my problem,both the reactant(Al) and the product of combustion(Al2O3) are particles.This means I must track Al and Al2O3 particle trajectories.Now I just know how to track the reactant(Al) particle trajectories,and I don't know how to track the product(Al2O3) particle trajectories.
Would you like to give me some advice?Thank you.
Old   March 4, 2003, 02:27
Stanislav Pagur
Hi, can you handle Al and Al2O3 as one particle, but with variable composition (rate of oxidation) -
you can separate flow problem (tracks of particles) and chemistry problem (particle composition)
thus you need to solve temperature - interaction between combustion and flow
BR, Stanislav
Old   March 4, 2003, 02:55
Devy
Thank you for your help. But how can I separate flow problem (tracks of particles) and chemistry problem (particle composition)? Do you have some cases about it?If you have such cases,would you like to give me? Thank you.
Devy
Old   March 4, 2003, 02:56
Devy
Thank you for your help. But how can I separate flow problem (tracks of particles) and chemistry problem (particle composition)?There aren't any TUT about it in flunet help.Do you have some cases about it?If you have such cases,would you like to give me? Thank you.
Devy
hydrocarbon gases + Boron particle combustion nileshjrane OpenFOAM 1 December 13, 2010 06:20
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
single particle combustion masoud FLUENT 1 December 15, 2004 10:36
CFX5.7 coal combustion and other reaction particle Leosding CFX 0 April 21, 2004 08:58
combustion of Aluminum particle in oxidant-rich ga Devy FLUENT 6 February 19, 2003 19:05
