On turbulent viscosity!
Old   March 5, 2003, 00:47
Default On turbulent viscosity!
Raintung
When I use Fluent to simulate 3D flow field (a thin fence on the endwall), the following information appears: ˇ°Turbulent viscosity limited to viscosity ratio of 1.000000+05 in 18 cells.ˇ± What does it mean? Do I need to reset any parameters? Do it affect computation results? What should I do? Thank you!
Old   March 5, 2003, 05:10
Default Re: On turbulent viscosity!
Chris
I get this message sometimes, but usually at the start of my iterations, when the solution is highly non-converged. (also applies to temperature, pressure, etc)
I would leave it alone, because if your boundary conditions are sound, with appropriate initialization, this statement will disappear after a few iterations. Do not worry about its effect on your final convergence.
If HOWEVER this statement persists for a long while, then your solution may not be converging, so you might want to consider running an inviscid solution first, to bring your solution closer to solution, before you activate viscosity.
Old   March 5, 2003, 21:49
Raintung
Thank you! I will try to do that.
reversed flow at pressure inlet and turbulent viscosity is limited.... cfdiscool FLUENT 10 June 10, 2015 06:15
k-epsilon problem: non-physical turbulent viscosity production in coaxial free-jet Felipeb Main CFD Forum 1 July 26, 2010 17:02
Turbulent viscosity and shear rate shib FLUENT 0 June 22, 2010 12:44
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 00:05
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
