May 11, 2003, 23:32 |
velocity more than INLET velocity
Have a simple geometry of a 1cm diameter pipe. After 3 cm (from left to right)length of pipe the diameter increases to 1.2cm expanding downward. Upper wall of the pipe remains same. Have now an expansion of length 7cm giving total of 10 cm. at left side of this geometry a velocity inlet is conditioned and at right side an outflow. Velocity is given 0.0015 m/s at left side velocity inlet. Displaying contours and computing min max veolity is giving maximum velocity 0.0019 m/s which is greater than 0.0015 m/s. Is the expansion causing the velocity to increase? Or any thing wrong?
May 12, 2003, 17:02 |
Re: velocity more than INLET velocity
The maximum velocity must be greater than 0.0015m/s if you set a uniform veolity at inlet, because the velocity becomes non-uniform inside the pipe. Is it turbulent flow?
May 13, 2003, 04:34 |
Once the flow is fully develloped you have a velocity profile. The velocity you entered is an average. Parabolic profile as below.
_________________________________ - v=0 -- --- ----v max --- -- -________________________________ Mcgregor |
May 13, 2003, 04:56 |
_____________________ - v=0 --- ---- ----- v max ---- --- - _____________________
Changing Boundary: Decreasing Inlet Velocity - Convergence Issues | VT_Bromley | FLUENT | 3 | February 12, 2011 09:02 |
User Defined Profiles, Swirl, Velocity Inlet | saurus | FLUENT | 0 | January 26, 2011 15:35 |
Unexpected difference between velocity / mass-flow inlet | jpo | FLUENT | 8 | December 10, 2010 07:20 |
UDF problem : inlet velocity in cyl. coord. system | Jongdae Kim | FLUENT | 0 | June 15, 2004 11:21 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
