Unsteady DPM
Old   May 12, 2003, 20:36
Default Unsteady DPM
Alex Munoz
Hi CFD USERS
I have to run DPM model under unsteady state conditions. I need to determine the number of time steps that I should request. Currently, I set a time step size of 0.01s with 25 iterations per time steps, and I get very good convergence of the continuous flow field.
Preliminary estimations lead to 250 time steps (path length 5m, particle velocity 2.0m/s, thereby a particle would cross the domain in 2.5s). Unfortunately, this number of iterations demands more than 33 hours. and I need to run more than eight times the DPM model.
As a result, I wonder if my estimations are right, and if could be another way to run particle tacking without requesting iterations of the continuous phase.
Thank you in advance
Alex Munoz
Itīs possible to use this in unsteady dpm tracking? JSoares Fluent UDF and Scheme Programming 3 June 9, 2011 10:41
steady or unsteady DPM ??? Marina FLUENT 5 July 5, 2006 04:52
Unsteady DPM Johnny FLUENT 1 February 22, 2006 13:43
unsteady DPM Thiyagarajan FLUENT 4 August 23, 2005 14:06
steady or unsteady? (in dpm) winnie FLUENT 1 April 28, 2003 11:30
