Porous jump and velocity
Old   May 13, 2003, 09:20
Default Porous jump and velocity
Christian
When using a porous jump we add a pressure sink. But what about the velocity after the jump? How is it affected regarding magnitude and direction? I cannot find documentation in the manual.
Cheers Christian
Old   May 13, 2003, 10:12
Default Re: Porous jump and velocity
Christian
Can I assume that the magnitude and direction of the fluid is the same on the adjacent porous jump cells ?
Old   May 13, 2003, 12:25
Evan Rosenbaum
The porous jump is just a momentum sink, the velocity direction and magnitude are determined as if there is no solid obstruction in the flow.
Old   May 14, 2003, 01:45
Christian
Thanks.
But "momentum" sink. Momentum = m*u (mass*velocity) right. If any of these two parameters are reduced, the velocity will eventually decrease. Or am I missing the point.
Cheers
Old   May 16, 2003, 14:15
Evan Rosenbaum
You're missing the point. The velocity that is used does not account for any area contraction in the porous jump. Let's say you have a perforated plate with 40% open area. You would expect the velocity in this section to increase by 1/0.4 = 2.5 times. It won't. The velocity in a porous jump is calculated using 100% open area (FLUENT calls it the superficial velocity), you have to account for the velocity effects when defining the porous jump parameters.
Old   May 20, 2003, 15:13
frank
We also made calculations with porous jump instead of the perforated plate. If the fluid flow is about perpendicular to the plate, the results seem to be ok. If the flow comes with a smaller angle to the plate, the results were bad. What is your experience with the porous jump model ?
Old   May 21, 2003, 13:24
Evan Rosenbaum
You have to recognize the impact that the angle of entry has an a perforated plate. Imagine you are holding the perf plate in front of you, perpendicular to your axis of vision. If the plate has round holes, they look round. Now tilt the top edge either toward or away from you. The holes look smaller as the projection ovalizes. You have to account for this when defining the porous jump properties.
Porous jump in urban environment samygero FLUENT 0 February 14, 2011 18:26
Membrane porous jump problem in VOF Hema kothimbare FLUENT 0 August 7, 2009 01:22
Porous Jump Naresh FLUENT 0 April 25, 2007 15:36
Testing the integrity of POROUS media and por jump Azman FLUENT 0 July 31, 2006 11:11
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
