UDF paraboloid velocity inlet
Old   June 4, 2003, 09:44
Default UDF paraboloid velocity inlet
Ronak Shah
Hi, I am new student working on the UDF paraboloid velocity inlet problem. I read the information posted by rosco <rosco1998@hotmail.com>Date: Sun, 18 May 2003, 11:37 a.m. subject: UDF paraboloid velocity inlet and the responses he received regarding his problem. I have a similar problem but the case here is the inlet is in the xy plane. or in other words the the origin of the reference system is not in the center of the inlet pipeinlet pipe, it is about 30 degrees from the x-axis. I am looking for modifications I would need in this code to have it work... Here's the code. Remember it requires you have the origin of your reference system in the center of the inlet pipe.
If you need to change diameter and average velocity, change their values in the corresponding #define.
#include "udf.h"
#define PIPE_DIAMETER 10.e-3 // Set here the diameter of your pipe in meters
#define AVG_Z_VELOCITY 1. // Set here the average z velocity at inlet in m/s
DEFINE_PROFILE(paraboloid_velocity, thread, position) { real x[ND_ND];
real coeff,r,v_max;
face_t f;
r = PIPE_DIAMETER/2.; //Calculating radius
v_max = 2.*AVG_Z_VELOCITY; //Calculating paraboloid vertex z (max velocity)
coeff = -v_max/pow(r,2.);
begin_f_loop(f, thread)
F_CENTROID(x,f,thread);
F_PROFILE(f, thread, position) = coeff*(pow(x[0],2.) + pow(x[1],2)) + v_max;
} end_f_loop(f, thread) }
(C) < copied from the reply to Rosco's question
Any ides on how I would go abt doing this?
Ronak Shah
3D UDF Paraboilc Velocity Profile (Can't Maintain) Sing FLUENT 12 August 7, 2017 06:25
UDF paraboloid velocity inlet rosco FLUENT 10 June 2, 2017 08:01
3D velocity inlet UDF zumaqiong Fluent UDF and Scheme Programming 2 October 24, 2016 04:44
USED UDF for inlet velocity in 3D sara FLUENT 0 October 11, 2007 18:04
Fluent UDF load and apply inlet velocity b.c. Knut Lehmann Main CFD Forum 2 June 29, 2007 04:53
