Unsteady flow to capture acoustics (press. fluct)
Old   June 24, 2003, 11:27
Default Unsteady flow to capture acoustics (press. fluct)
Ana Garcia
I am trying to compute the flow around an airfoil using an unsteady segregated 2d order implicit Fluent calculation. I am interested in obtaining the pressure fluctuations on the surface of the airfoil.
Even if I am using as initial condition a fully converged steady solution it takes quite long time(small time step and hence need of many time steps to solve the domain). I am not sure that I am obtaining an unsteady field and even if it is possible for Fluent to resolve this small pressure fluctuating field. Or which things should I take into account for it to be able to solve it.
I am using a structure grid stretched near the surface and the k-epsilon realizable turbulence model.
I would appreciate any ideas/comments that can help me with the calculation. I plan next to check an inviscid calculation and see if it gets faster/better having simplified the equations.
Many thanks in advance.
Best regards,
Ana
Question on Unsteady Flow Ben CFX 5 January 17, 2008 17:04
Unsteady flow in FLUENT Vidya Raja FLUENT 2 November 2, 2005 16:29
3D unsteady flow simulation Wason FLUENT 1 May 6, 2000 05:46
computation about flow around a yawed cone Tylor Xie Main CFD Forum 0 June 9, 1999 07:33
Initial Conditions in unsteady turbulent flow Z. Zeng Main CFD Forum 5 April 28, 1999 17:38
