Standard wall function vs Two layer model
Old   July 7, 2003, 08:35
Default Standard wall function vs Two layer model
C. ORTEGA
Hello
I've been using the standard wall function and two layer model to represent the boundary layer for the turbulent flow across a set of obstacles that represent an idealised filter. I have followed FLUENT guidelines to create grids for each approach. When I use the standard wall function I get pressure drops that are 50-60% larger than the value I get in the laboratory. The use of the two layer model matches perfectly the experimental values. That is for when I model the problem as a 2D analysis. When I model the problem as a 3D analysis. The use of the standard wall function and the two layer model does not make any difference giving both approches the same value I get in the lab.
Any comments would be very appreciated.
Thank you
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
nut wall function for Spalart Allmaras model wei_wu OpenFOAM Programming & Development 0 February 9, 2010 16:30
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
3-D turbulence model with wall function Henry Main CFD Forum 7 May 19, 2006 10:40
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
